Load testing new 12v motorcycle (or UPS) batteries to make sure you got a good one
Lumenosity
Joined Mar 1, 2017
614
I just received a large shipment of battery backup batteries for the numerous battery backup devices I have.
Most of them are 12v and around 7 - 8Ah but some are larger.
I'm mostly concerned about the 7-8Ah batteries.
I know there are commercial load testers available, but I don't trust them too much after reading all I could.
What I would like to do is rig up a home made load tester using a known load.
Let's say a load of somewhere around 5 - 8 amps. That's easy to do with a headlight bulb for example.
So in this example, let's say I have a headlight bulb that draws a known current of 6.3amps (because that's what I have)
The load test in basic terms will answer the question: How long can this 7.2Ah battery run a 6.3A bulb?
Until it dims? That's not very scientific. So what I'm asking is, what would be the right way to administer this load test?
Would I run the bulb until the battery amps drop below a certain amperage or would I run the bulb until the VOLTAGE drops below a specific voltage?..and for a 12v, 7.2Ah, AGM battery how would I know what that voltage (or current) is?
ian field
Joined Oct 27, 2012
6,536
Motorcycles with electric start usually have a battery somewhere between 9 - 15Ah
I routinely used the starter on a small motorcycle to check UPS batteries.
Some UPS boxes refused to run even though the battery passed the usual tests - the motorcycle starter was sluggish and pointed out the dodgy batteries.
Don't worry about stressing a 7Ah battery on a 9Ah motorcycle - I've got away with 10x 4Ah D-cell Ni-Cd acouple of times.
