LMV358P PDF Interpretation
SamR
Joined Mar 19, 2019
5,538
LMV358D, LMV321DCK, LMV321SINGLE, LMV324D, LMV358PW datasheet (datasheetcatalog.com)
Looking at the PDF description section I see "The LMV324 and LMV358 are low-voltage (2.7 V to 5.5 V) versions of the dual and quad operational amplifiers, LM324 and LM358, that operate from 5 V to 30 V. The LMV321 is the single-amplifier version."
But then under the absolute maximum rating section I see:
So it's limited to a IN+ to IN- V of 5.5Vmax and Vcc to Vdd is also 5.5Vmax? So what is this operate from 5 V to 30 V? A misprint erratum?
MrSalts
Joined Apr 2, 2020
2,767
It does not say the LMV operates at 5 to 30V. It says the LM358 operates at 5 to 30v and the chip you have is similar in many ways except, that it operates at 2.7 to 5.5v.
Jon Chandler
Joined Jun 12, 2008
1,647
The LVM324 and LVM358 (which operate from 2.7 – 5.5v) are low voltage versions of the LM328 and LM358 (which operate from 5 – 30v).
It could have been more clearly written.
The datasheet is comparing the low voltage part LMV358 to the old HV part LM358:
"These amplifiers are designed specifically for low-voltage (2.7 V to 5V) operation, with performance specifications meeting or exceeding the LM358 and LM324 devices that operate from 5 V to 30 V. "
It is a 5V part. EDIT: there is also an improved part LMV358A but no mention of the old 30V part in that datasheet.
MrSalts
Joined Apr 2, 2020
2,767
It's like saying, the Ford F-250 is the higher capacity pickup truck (4300 lb payload) version of the standard pickup truck (F-150) that has a capacity of 3300 lbs.
