LM7812 I need to boost the current to 3A
WBahn
Joined Mar 31, 2012
33,178
Walk it back from what you want to what you need.
How much current do you want going through the regulator when you have 3 A being delivered to the load?
dl324
Joined Mar 30, 2015
18,463
i need a 3 amperes output, what must be the value of the resistor?
Rearranging the divider equation from above and assuming maximum of 1A in the regulator:
\( \small \frac{I_1}{I_{REG}}=\frac{R_2}{R_1} => \frac{R_2}{R_1} = 2 \)
You want to use low value resistors to minimize wasted power, e.g. R2 = 0.2Ω, R1 = 0.1Ω.
I have a 2 amperes transformer, can I use the transformer?
No. A non-center tapped transformer would provide a little over 1A; 1.1A from the equation above.
