lm339
Dritech
Joined Sep 21, 2011
907
Hi all,
Is the LM339 output a digital output (schmitt trigger) ?? and is it good to compare small voltages such as 0.3V ?
Thanks in advance
34,810
Yes and Yes.
The LM339 is open collector output.
is not the right question.
Comparators work by comparing one input with another.
You can set a reference voltage to whatever voltage you wish as long as you satisfy the input operating range.
Dritech
Joined Sep 21, 2011
907
Thanks for the reply. Another question; is there a similar IC but with a single or double comparator which is not SMT?
Wendy
Joined Mar 24, 2008
23,798
Yes. A LM393. It is a 8 pin dual.
SMT packges are optional, refer to the data sheet. You can get a LM339 from Radio Shack as a 14 pin DIP.
34,810
Many comparators, including the LM393 are open-collector, which means the output is uncommitted. Put a pull-up resistor from the output to +5V. Any value from 1K to 10K ohm should work.
38,504
What does open-collector mean? and is there a similar IC with a Schmitt Trigger?
"Open-collector" means the output consists of a single transistor (NPN here) with the collector open and the emitter to ground. Thus you need to add a resistor from the collector to V+ to see the output change state.
It you look at the data sheet (heaven forbid) you will see this.:rolleyes:
This output transistor turns off (output goes high) when the plus input voltage is greater than the minus input voltage.
I don't know of any comparator ICs with a build-in Schmitt trigger but you can add hysteresis (which acts as a Schmitt trigger) to any comparator by adding a small amount of feedback from the output to the plus input using a pair of resistors.
38,504
Thanks. If i add a pull up resistor, it should work as a schmitt trigger, right?
No.
Perhaps you are confusing a comparator function with a Schmitt Trigger function.
A comparator changes output state from high and back to low at nearly the same input voltage (as determined by the open loop gain of the comparator amplifier).
A Schmitt trigger is a type of comparator that has hysteresis, which means it changes to output state high at one level of input voltage and changes back to output state low at a different level of input (a lower voltage for positive voltages) to minimize oscillations from noise or stray feedback.
Standard comparators do not have this hysteresis built-in and it must be added by a small amount of positive feedback from the output to the plus input, as I stated in my previous post.
Wendy
Joined Mar 24, 2008
23,798
The key thing about Schmitt Triggers is their hysteresis. They switch at two different voltages.
http://en.wikipedia.org/wiki/Schmitt_trigger
The vast majority of comparitors (so there Ron!) compare the two input voltages, and have a one or a zero depending on which voltage is greater. A common nick name for a comparitor is a single bit A/D converter. They can also be used to make full scale A/D convertors.
http://en.wikipedia.org/wiki/Comparitor
An op amp and a comparitor are related, but a comparitor is designed to only output a digital value, whereas a op amp is a linear circuit.
You can make a true Schmitt Trigger with either a op amp or a comparitor and two resistors, but since comparitors are truely digital they are much faster.
Open collector is also a common digital technique in the I.C. world.
http://en.wikipedia.org/wiki/Open_collector
