LM339 Comparator and capacitor discharge
marigold.maripol
Joined Aug 19, 2015
Hi-
I'm having some on-going trouble and I can't quite figure out what the problem is.
I'm running a fairly standard comparator circuit, as attached below.
It is being driven with the signal from a full-wave rectified bipolar op amp.
From my understanding of the datasheet, the LM339 should be able to be powered by +/- 12v. I am running it from that because I want -V and +V at the output, in order to discharge the capacitor.
When I breadboarded it, it worked. When I built it worked, then it stopped working. The capacitors no longer seem to discharge effectively. Replacing the IC doesn't help. Rebuilding the whole circuit does work - again, just for a little while.
Can someone suggest a way to solve this problem?
38,952
Design error. :eek:
You didn't look at the rest of the data sheet to see the output maximum sink current.
Here is that value:
As you can see, it's typically 16mA with a worst-case value of only 6mA.
You have a 1k output resistor going to (apparently) +12V with an LM339 negative voltage of -12V.
This means the current through the resistor would be near 24mA when the output is at its minimum (near -12V), but that won't happen, of course, because that's much higher than the LM339 rating.
So to keep the current no greater than the worst-case 6mA value, the resistor should be no smaller than 4kΩ.
