LM25145 Pspice to LT Spice conversion
eetech00
Joined Jun 8, 2013
4,723
Hi
The spice file is encrypted so cannot be used with LTspice.
You might contact TI and ask if they will provide an unencrypted version.
eT
eetech00
Joined Jun 8, 2013
4,723
Thank you for your response. I did contact them and I was provided an alternate unencrypted model of LM5145 instead of LM25145. This lib file is in Pspice as well. Is there a way to convert this file so that I can use in LT spice? I have attached the lib file for reference as well as the link.
http://www.ti.com/product/LM5145/toolssoftware
Thanks.
Sometimes the pspice file will run without modification.
Try it. If it produces errors, I will convert it for you.
eT
Bordodynov
Joined May 20, 2015
3,431
But my adaptation. I reduced the number of elements and nodes of the circuit. I did not test this model. When I adapted another model in it, like this model the generator is built on a switch. And this generator did not work. I had to do a generator on specific elements of LTspice.
Model:
del_ee
Joined Sep 20, 2013
Model:
Thank you Bordodynov
I've been trying to fix the LM5145 model to make it work (I'm using LTxpice XVII 5/20/19 version), and stumbled across this thread. Yours was the only one I could get to actually run.
