LM1875 worked ! But there is a problem
Mohamad Tarabah
Joined Jul 4, 2016
54
Hi all, thanks to everyone's help, especially administrators answers the opamp circuit work. Now the problem is it's not outputting 20w : I'm trying it on a 5w 4ohm woofer and also tried to power it with 24v using lead acid batteries, still same. Please note that the 1uF cap at Vin is replaced by a polarized capacitor. I'm thinking of removing the 2200uF cap at out. What do you think ?
bertus
Joined Apr 5, 2008
22,925
The 24 volts is way to low for 20 Watts.
At 24 volts you might expect about 5 Watts, as you are using single supply.
The 2200 μF capacitor is a must for a single supply amplfier.
Without it the speaker will have a high DC of about 1/2 the supply voltage.
Bertus
AlbertHall
Joined Jun 4, 2014
12,625
From the datasheet:
Using a single supply that means 50V or 60V.
Note that the capacitors have to be rated to handle these voltages.
You will get about 1.4 times the transformer voltage after the rectifier (assuming a full wave bridge) and smoothing capacitors so the transformer should be 35V to 42V.
R!f@@
Joined Apr 2, 2009
10,004
Is it designed to handle 50V Vcc?
{ed}
So it seems it can handle 50V.
Beware if you are using 4Ω Speaker.
38,512
If you want more power from a 24V supply then you would need to use an audio amp with bridge type output, as that doubles the voltage across the speaker load for a given supply voltage.
