LIS2DW12 Accelerometer
sara mell
Joined Jul 8, 2024
11
Has anyone ever used LIS2DW12 accelerometer by STMicroelectronics for a design? do you know if the accelerometer is capable of providing Output Data Rate (ODR) = 5 Hz or a number around this value, for example, 6.25 Hz? I couldn't find 5 Hz specifically in data sheet that the manufacturer provided, I would appreciate any help?
Cheers,
sghioto
Joined Dec 31, 2017
8,765
The spec sheet gives ratings for several different ODRs. Just because it doesn't mention 5hz doesn't mean it can't be setup for an ODR of 5hz. As stated the ODR from 1.6 to 1600hz.
28,629
ST is a good enough company that their website should provide contact information for product applications.
If you are hoping to use the accelerometer in a product I am sure you can get all the tech application support you could need.
