Lipo solar lamp design
Gwenbino
Joined Apr 23, 2020
Good morning,
I am a student in electronics & would like to ask about my solar lamp design which is far from perfect.
I want to use a 6V solar panel to charge a lipo through the TP4056 charging board. On the side I would like to do a night detection circuit to activate my solar lamp when the sun is down enough.
I have first tried to build it with 2 NPNs as described in the attachement LT spice simu with the name " solar led driver NPN". The design seems to work but I am not really in total control of what is going on there. I would like to understand how to tune my circuit resistors & values in order to for example switch it on when the solar panel voltage drops lower than X Volts. Could someone enlight me onmy mistakes & which parameters to tune there please?
I then found someone on the internet telling to use a PNP which seems to give me a much better result, even tho I am really having a hard time understanding how that circuit works. I have again no control over the system & would like to understand it & be able to tune the parameters in a comprehensive way.
thank you for your time & consideration.
Best Regards;
Gwen
In blue I plotted the solar panel discharge voltage; In green the current flowing through the LED.
wayneh
Joined Sep 9, 2010
18,181
So this is homework?
What controls the conduction of the two transistors? Do you see a way to manipulate those controls?[/QUOTE]
ci139
Joined Jul 11, 2016
2,037
there are ready made (low quiescent power) modules (controllers) on the market ← it's hard to beat by something made of discreet parts
? are you trying to make this as a real thing or just simulate in spice
if it's to build - it might go tricky as you increase the number of the required options . . .
? your power input profile
  • simple - assumes the clear sunny day
  • complex - can boost the input at cloudy day / low sun
? your power output
  • simple - goes (fading) , as long as there is power avail
  • complex - uses switched CC output . . . perhaps goes to a beacon mode at low power
? module control
  • simple - (no controller) current limit charger / enough batteries to ensure they never overcharged
  • complex - device controller ← here it requires to detect the system state (if there is enough power from solar or battery input for it to run) , etc. ... a lot of things to consider/add/control as programmatically as and extra "harware" to detect system parameters . . .
Hacking an LED solar garden light - Blogs - Virtual Classroom for ADI University Program - EngineerZone ← a commercial variant
Gwenbino
Joined Apr 23, 2020
First of all thank you for your time & consideration on my question.
No, it is not, this is for my personnal learning curve, I am repairing my moms solar lamp, & it is quite easy since it is often just changing the Nimh battery or resoldering a faulty button. Yet I have noticed that there are either a joule thief circuit ( on the super cheap ones I believe) or some using dedicated ICs & Nimh battery. I enjoy working on electronics on my spare time & made few instructables already. As a project I decided to use what I had laying around & try to make my own solar lamp (not optimal but with a proper working concept) using my lipos, the charging board I had & no MCU, just a night detection IC thatshould be easy to make.
[/QUOTE]
I wanted to do it just with the dropping voltage of the solar panel & some PU/PD, yet this is maybe where I am making a mistake..
Gwenbino
Joined Apr 23, 2020
first of all, thank you for your answer.I replied to your questions right below;
I know about these but I want to use my components laying around & acquire more knowledge on those NPN & PNPs.
I actually built the NPN circuitery on PCB board & plugged it to my solar panel & charging board, it kind of works as the simu, yet I am not fully in control which means I didnt understand everything I did, therefore I asked for help here.
? your power input profile -> Simple
? your power output -> Simple
? module control -> Complex, even tho I am aware that it is dangerous to mistreat Lipos & misshandling them could end up with a fire. I am trusting this Lipo TPU board charger. Since my solar panel is a cheap 6V, with a low current output, I am assuming nothing too bad would occur & therefore I am really focusing on the transistor part of the circuit, that night detection circuitery.?
Thank you again.
Gwen
ci139
Joined Jul 11, 2016
2,037
https://lygte-info.dk/review/Review Charger TP4056 UK.html
hints the LiFePo is not supported by that particular charge controller ???
+cite from the site "The board needs a 5 volt power supply," so you may want to add 1N4004... + 1N5817... to get apx. 1V drop
? what's the exact battery model you are using ?
you are almost right about your experiments
Fig_1-1.gif Fig_1-2.gif Fig_1-3.gif the R=0 may cause the simulation to hang or not start at all use "NO RESISTOR" or 2µΩ instead of 0Ω superconductor
Gwenbino
Joined Apr 23, 2020
Good call for the voltage drop, my bad on that.
I am not using the proper terms on that, sorry, I have Li-ion batteries, 18650. Max charge is 4.2V & I believe they're supported by the TPU, having a look at the chart they give us.
