Hi
I am using some v small unbranded Lipo batteries with a capacity of 30mAH. Like these ones:
https://www.ebay.co.uk/itm/5-pcs-30...315864?hash=item28397efe98:g:oogAAOSwaeRZIkpA
I have been charging them with the generic cheap charging modules based around the TP4056 chip like this
https://www.ebay.co.uk/itm/Mini-USB...562474?hash=item233a92ebaa:g:4WMAAOSwo4pYP~6s
The vendors of the modules rarely mention the fact, but the the TP4056 is configurable by a resistor, depending on the battery capacity. I believe most of the ones sold have a 1.2k resistor which is suitable for a 1000mAH battery
TP4056 datasheet here:
https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf
It does not mention a battery capacity less than 130mAH.
Somewhat concerned, I measured the current going into the charger using a bench supply set to 5V, and a discharged battery (I don't know whether it is really discharged: it measures 0V - but I think it contains circuitry to cut off below 3V)
The current was initially about 200mA but within about 15 seconds it fell to about 50mA and 10 minutes later was down to 11mA and falling. About 2mA of this is accounted for by the charger itself. The initial current is high, but it doesn't last long, and 11mA or so seems about right. The battery doesn't get warm.
Should I be concerned about this from the point of view of a) safety and b) battery life, and replace the resistor?
