Linux Help, ALSA issues
Travm
Joined Aug 16, 2016
363
Hi, Posting here because I believe there are a few on this board with a far better grasp of how the linux system works.
I"ve been having a minor issue with my Chromebook(GalliumOS 3.0), it wont save alsa sound settings. I've chased the issue to the alsa-utils startup/shutdown script, reached out to the developer, and was given this as an explanation.
"I think that the card may not be available at boot, because it loads the firmware and it may take some time. Use udev rules to resolve this issue like: https://github.com/alsa-project/alsa-utils/blob/master/alsactl/90-alsa-restore.rules.in (the final rules file is available after make)"
Can someone help translate this? Specifically what does he mean by "the final rules file is available after make"?
Do I have to reinstall alsa-utils from source?
Is it enough to copy this file (removing the .in) to /etc/udev/rules.d/?
