line filter for 12v supply
Guest1999354
Joined Nov 20, 2015
11
I have a camper trailer that has a built in 12 volt power converter/ battery backup system. I wish to install a car stereo in my trailer and run it from the 12 v DC supply, however the power supply is very old and its line filter has failed. There is AC hum in the line, which doesn't bother the DC lights. But I'd assume would damage a stereo. Without tearing the power box out and replacing the capacitor inside, how can I clean up that hum so it will run a radio without damaging it? This is a 12 volt supply @ 15 amps. Can I insert a capacitor across the line I will be using for the stereo? What value cap would I need?
dl324
Joined Mar 30, 2015
18,336
Putting a cap across the leads out of the power supply is the easiest solution. Without knowing how much ripple you're talking about I'd start with 1000uF.
