Hi there.
I have a project to complete, in which I need to have an increasing resistance (using a potentiometer), which will then light up 4 LEDs after each other. For example, if the pot starts at 100 ohms, the first LED is on. The pot increases to 500 ohms (exact values are not important), the first LED switches off and the second LED switches on.
I've attached my circuit diagram for how I thought to solve this, but it doesn't seem to work. I'm guessing the tolerances of the resistors are at least part of the issue, but I may be wrong. Any advice on how I may solve problem, or what different approach I should be taking?
