Light sensor to Arduino.
Lightium
Joined Jun 6, 2012
320
A combination of values should get me 5 volts on the analog pin, but changing R4 or R7 changes the voltage in an unpredictable way.
ericgibbs
Joined Jan 29, 2010
21,651
OK,
Assuming the signal limits, what will be the maximum Photon intensity and I assume that you would expect a +5V maximum signal on the ADC input at that Photon level.
Could you explain the purpose of the project, so that I can get a better understanding of its use.
E
Lightium
Joined Jun 6, 2012
320
I don't know. I have to familiarize myself with a datasheet, because I forgot where I left-off with this circuit.
