I had trouble reproducing your result. What do you mean by V(Vin) ?I tried that, but the sim didn't seem to converge.
In LTspice, V(Vin) is the voltage at node labeled Vin.I had trouble reproducing your result. What do you mean by V(Vin) ?
Hi,Correction.
I was wondering why the series simulation values were some different than my previous sim of them separately, and I found an error in the series sim.
I was using the Vin voltage for the 25W bulb equation instead of the node 1 voltage.
The corrected sim below now agrees with my separate simulation, (but unfortunately not as close to OBW0549's measured values).
Ok no problem, i usually use lower case 'v' but that's ok.In LTspice, V(Vin) is the voltage at node labeled Vin.
And I see you also use i for I.i usually use lower case 'v' but that's ok
Hi,And I see you also use i for I.
Spice, of course, ignores the case of a letter, which has caused much simulation results confusion for newbies who try to use M for megohm.
