Light glows even after it is switched off
gknathkumar
Joined Oct 24, 2023
10
I would like to understand the reason for a light that keeps glowing in low even when it is turned off in the night.
When it is actually on:
When it is actually off:
Some may say it may be due to leakage current, but I have tested the power supply by removing the bulb and testing it with AC tester on the holder and there is no supply at all. Then I was wondering how it glows?
WBahn
Joined Mar 31, 2012
33,342
Does the switch have a little indicator lamp that turns on when the light is off? If so, that works by passing a small amount of current through the lamp. Historically, that amount of current was too low to see any light. But those were the days of incandescent bulbs. With modern bulbs, all bets are off.
LesJones
Joined Jan 8, 2017
4,544
You could put a resistor in parallel with the LED lamp to reduce the voltage caused by the capacitance between the conductors. The problem with this is that the resistor would disipate power and heat up when the LED was switched on. To get round the heating problem I have used a capacitor instead of a resistor. I find the most convenient way is to use a contact suppressor (Which is a capacitor in series with a low value resistor.) Many of these have flexible wire connections so they can be connected straight across the LED lamp.
The current in the capacitor is out of phase with the voltage so no power is disipated so no heat is generated.
This is one example of a contact suppressor.
Les.
28,576
If this is a low power LED bulb, and IF it is a "3-way " switch arrangement where there are two different switches that can switch the light on or off, then it might be capacitive coupling between the two wires that connect the two switches.
Next question: What part of the world is this located in? and what is the mains voltage?
AlbertHall
Joined Jun 4, 2014
12,663
We had a problem after the supply cables to the house were replaced.
The fluorescent strip lights would flicker even when switched off. This turned out to be because the supply wires had been swapped so the switch was now in the neutral wire to the light but the live wire was permanently connected.
28,576
The problem of the reversed switching connection indicates a lack of competence on the individual who replaced the wires. Either careless or unknowing.
DC_Kid
Joined Feb 25, 2008
1,251
Use a different LED bulb.
And as MrBill mentions, it's a 3-way wire configuration, not a "2-way".
There's more than one way to wire a switched 3-way ckt (bad ways, and the right way), but it should be noted, the hot side of the wiring on fixture should always be interrupted by a switch toggle.
I would turn off the light, pop the bulb out, and then use a contactless volt probe to see if that socket dings hot.
28,576
There are two arrangements with the "3-way" that function correctly, all the others are incorrect. AND it is possible that the common side is switched and it is either capacitance to common of the two conductors or leakage or funny lights. I did get a case of LED bulbes that include a battery and they do switch on and off when the mains power fails.
So the first step is to check by installing a NON-LED bulb an see what happens. No great skill or equipment required.
Pyrex
Joined Feb 16, 2022
577
Hi
the problem is well known for me. And was solved several times- just put capacitor 0.2-1 uF 250VAC or 630VDC in parallel to the lamp. Small current will pass the capacitor. Resistor, in general, can also be applied, but it is not recommended as it consumes power and dissipates heat
