Light Emitting Wire
cryptosaint777
Joined Jun 1, 2021
22
I am an electronics hobbyist. I have noticed that a common and boring component the Light Emitting Diode has a specific voltage drop across it. For example, a red LED has a voltage drop of 1.7-2 vdc. This is interesting, because it is the same value for the energy of a red photon (1.7-2 electron volts). Perhaps it is possible to generate a specific color of light from a low voltage AC current. Any thoughts?
Currently I am working on constructing such a power source to test it.
Deleted member 115935
Joined Dec 31, 1969
nope is the answer,
Leds work due to some sort of quantum , tunnel effect across a band gap ,
a specific junction size / type gives off a specific wave length
The brightness is proportional to the current, which is why leds need a current limit on the ( typically a resistor )
https://en.wikipedia.org/wiki/Light-emitting_diode
there are tri colour leds,
with separate wires for each led,
if we chose the r g b type led, then varying the current to each led changes the colour.
cryptosaint777
Joined Jun 1, 2021
22
I am fairly certain it will work. I will be targeting 2.3 VAC at 300 mA. I will be generating a square wave with a 555 timer, which will activate a pair of zener diode voltage regulator circuits, one on an inverter, which will pulse at about 20khz through a ferrite core inductor with 3-5 turns.
Joined Dec 31, 1969
we look forward to your results
what led are you using ?
BTW: if it does work, ensure you pattent it before you post in public
cryptosaint777
Joined Jun 1, 2021
22
How does that explain the forward voltage of a high power LED that can easily reach 2.5 or more volts?
A white LED is 3 or more colors, the blue voltage drop is about 3.3 volts.
Thank you for your encouragement. I will not be patenting anything, if someone else does it first that is okay.
BobTPH
Joined Jun 5, 2013
11,678
There are AC currents of many voltages and frequencies going through a coil in every loudspeaker. Why don’t they produce light?
Bob
BobTPH
Joined Jun 5, 2013
11,678
Actually there is light being emitted by any wire carrying current, you just can't see it.
IR
In fact......
Why dies it have to be carrying current? Any object that is not at absolute zero is emitting light.
And if the wire is carrying enough current it will emit visible light.
Bob
Papabravo
Joined Feb 24, 2006
22,116
Coincidence. There is no actual connection between a volt which is a measure of potential energy and an electron volt which is a measure of kinetic energy. So dividing kinetic energy by a standard velocity, usually the speed of light, gives units of momentum which is the usual context for the use of the electron volt. Your quest is both fruitless and pointless.
Ian0
Joined Aug 7, 2020
13,317
When an electron in a semiconductor
Certainly.
But the only way to get visible light from a wire is to run enough current through it so it heats up to incandescence (I think someone named Edison beat you to it :rolleyes:).
I think Joseph Swan was there first, but Humphrey Davy demonstrated incandescence in metal wires much earlier.
Joined Dec 31, 1969
Certainly.
the OP is looking for light from the LED, not the wire,
getting different colours from a red led by varying the voltage still wont change the colours ,
bu ti is the led,
