light dependant switch
jomass
Joined Feb 12, 2010
2
hay i got a clock that cant be seen at the eve and from early day hour so i want to connect a source controlled by a light sensor to light when there r no enough light well how u can help me
just give me the design or the ic to make it even if it has some additional things
thanx
bertus
Joined Apr 5, 2008
22,995
If this is a homework question, you will have to show us what you have upto now.
We will help you if you have troubles with parts of the solution.
Greetings,
kraudio7
Joined Feb 12, 2010
1
hey there jomass
I'm pretty new to the forum here, but as Mr. Bertus said, you must show what you've done until now before we solve your problem.
As being new here and to electronics, I can tell you I would use a MOSFET and an LDR. Can't say more or other wise I'll solve the exercise :D.
Search for those and see if you can solve it!
Good luck!
ELECTRONERD
Joined May 26, 2009
1,147
Have you ever seen those automatic night lights? It uses as CdS cell to detect whether it's night or day. Depending on those conditions, it will then turn on the light at night time, and turn it off at day time. This is, in effect, the same requirements you need, correct?
And no, I don't sleep with a night light! :D
Austin
