Lifetime Battery
LowQCab
Joined Nov 6, 2012
5,102
Kinda silly to go to all that trouble to create a cluster-F in your Battery compartment
when you could just go to Walmart and buy a
Battery Charger complete with 4-AAA Rechargeable-Cells for about ~$12.oo .
Then just swap-out the Batteries once a Month.
Better yet ......
Make a massive improvement to your Quality-of-Life by throwing-away your entire TV.
As for tearing-off the protection/charging Circuitry from another Battery,
it's a complete crap-shoot as to whether or not you "might" get it to work with a different Battery.
You might just start a fire.
zarish123
Joined May 3, 2021
12
Better yet ......
In the remote controls in my house most of the operate from two AAA cells and last about a year, maybe more, and that includes the television in the living room and air conditioners in most rooms. Pretty cheap to operate.
You were born 100 years too late. :rolleyes:
I want to know the charging circuit
Ramussons
Joined May 3, 2013
1,572
Does the charging circuit in this video work?
The answer to your question is Yes.
A charge controller from another Li Ion cell has been salvaged for the purpose. If it has not been damaged in the process of cannabalising it.
Its a different issue whether you want to go through the process.
zarish123
Joined May 3, 2021
12
If you want to learn about battery charging circuits, that's a pretty bad source. What application do you have for the charger? What kind of battery will you be charging?
Yes, if you try to cannablise the controller. Not if you use the controller in your photo. It will work OK.
thank u friends
