A very interesting concept to complement, if not completely replace, WiFi:
http://www.foxnews.com/tech/2015/11...-than-wifi.html?intcmp=hpffo&intcmp=obnetwork
The way I understand it is each light source will be fitted with an a receiver transmitter so the light does not necessarily be on. But would that mean special lighting fitted with those devices? And how do you communicate from room to room?Seems like a step back to me. While speeds may increase, there are plenty of downfalls. You can't use your computer to access the internet in a dark room, for example, can't use it outside, can't use it when it's bright and sunny, not to mention having to route internet cables along next to your AC power cables. I just don't think it's viable, personally.
Matt
As I understood it the data would be transmitted by the light.The way I understand it is each light source will be fitted with an a receiver transmitter so the light does not necessarily be on. But would that mean special lighting fitted with those devices? And how do you communicate from room to room?
My point exactly.Then the light would need to be on? That would not be practical.
Infrared, anyone?My point exactly.
Would still require LOS, and still would not work in a brightly-sunlit room. Not practical.Infrared, anyone?
Yes unless the team somehow magically eliminated the laws of physics.Would still require LOS, and still would not work in a brightly-sunlit room. Not practical.
The article does mention that outdoor use is a weakness. But maybe they have solved key technical issues with indoors use that give the technology a competitive opportunity.This has been tried before and failed to catch on. Maybe these people have fixed whatever the problem was (maybe financing or licensing). But what about outdoor use?
Outdoor use? Imagine a nice cool white LED source with lots of stray blue/UV emissions. Like attracting May Flies with a Mercury Vapor light. Imagine the bugs in the communications.This has been tried before and failed to catch on. Maybe these people have fixed whatever the problem was (maybe financing or licensing). But what about outdoor use?
