LGA-16 ecopack 5x5mm pitch 1mm footprint un traceable
Picbuster
Joined Dec 2, 2013
1,062
Readers,
I do have a problem;
Can't find footprint/landmark Lga-16 eco pack 5x5mm with a pitch of 1mm.
I do have the LGA-16 package information however I like to work from footprint dimensions.
It seems to be strange that this information is not available.
Product (Lis3dhhc this is a ST thing).
Please share if one of you have this info.
Thanks in advance.
Picbuster
jpanhalt
Joined Jan 18, 2008
11,087
You have the Gerber files for the breakout board. I don't know what is current, but something like "Gerbview" will show you. Alternatively, that is a rather large chip and spacing compared to many others. Why not take the pad sizes of the chip and puff them out about the same amount as similar ships with smaller pad spacing (e.g, QFN-16)?
Picbuster
Joined Dec 2, 2013
1,062
That's no problem I can easy make a footprint from the chip layout but I need more information.
Like the thermal pads and the 'no go fields" to avoid tracks under this chip.
I did try to obtain this from ST no luck so far.
Picbuster
jpanhalt
Joined Jan 18, 2008
11,087
As I said, the Gerber files are available with the breakout board (BOB). An answer to those questions should be in those files. At least the example whoever designed the BOB used.
