ebeowulf17
- Joined Aug 12, 2014
- 3,307
Personally, I'd stick with 270 ohms, or even step up to 330 ohms because of the lower Vf values. Human vision perceives brightness in a logarithmic way, which means you can reduce the current significantly with very little visible difference in perceived brightness. Running LEDs with lower current makes them last longer and fade slower... so in the long run you might actually have brighter LEDs by running lower current and fading less over time!It is been awhile - and I finally got most parts from Amazon.
I tested the leds and saw that the red and orange are 1.8V and the blue are ~2.8V, little bit lower from the values published by the seller.
So If I will use 12V 2a power supply and will build it as recommended above - 25 strings of 4 leds (mix of red and orange), 1 string of 2 blue leds (for the eyes):
Would it be OK (and bright ) if I will use 240 ohm resistor for each red/orange string and 320 ohm resistor for the blue string?
And one last question - I have this PWM motor that I've used in different project. can I use it with this setup as dimmer?
https://www.ebay.com/itm/351491759896?ViewItem=&item=351491759896
Thanks for the explanation and guidance
Zohar
Your plan runs them right at their rated current of 20mA, which is ok, but seems unnecessary. Either way is fine, but if it were my project I'd go 270 or 330. Maybe you should make one string each with the three different resistance values and see for yourself how small the difference in brightness is.
