LED spectrum analyser.
Mohammad Mohiuddin
Joined Feb 7, 2017
8
Hi, I am a beginner in electronics world. Just I made a LED spectrum analyzer with IC LM3915N. I use 2 IC (LM3915N) for left and right. I add 10*3 LED (normal 2 pin) for each IC. IT's working fine. But I want to add more LED (like 10*10) for each IC. Could possible? If so could anyone help me on this. Another point, if I want to use RGB LED instate of normal LED, what is the circuit diagram.
Anjon
DickCappels
Joined Aug 21, 2008
10,662
Please post your schematic and any other descriptive information available so we can answer your question.
What is it that you wish the additional LEDs to do -give a wider frequency range, indicate amplitude...or?
DickCappels
Joined Aug 21, 2008
10,662
This looks like a simple bar graph circuit rather than a spectrum analyzer.
What do you want the additional LEDs to do? Greater voltage range, finer resolution...?
absf
Joined Dec 29, 2010
1,968
Using LM3914 for the verticle and 4017 for horizontal scanning, you can make a 10x10 LED scope.
For better sensitivity, you can add an opamp before the LM3914.
Allen
DickCappels
Joined Aug 21, 2008
10,662
Now you have two different solutions that do different things, but you still have not told us what you want the extra LEDs to do.
