MaxHeadRoom
- Joined Jul 18, 2013
- 30,887
;. But where the hell is the CONFIG register?
; Configuration Bits
; NAME Address
; CONFIG 2007h
Max.
Oooooohhh... keyyyyy .... why am I not seeing that in the memory map? (baby steps, Max!);
; NAME Address
; CONFIG 2007h
Max.
; NAME Address
; CONFIG 2007h
; The following is an assignment of address values for all of the
; configuration registers for the purpose of table reads
_CONFIG EQU H'2007'
;----- CONFIG Options --------------------------------------------------
_FOSC_INTOSC EQU H'3FFE'; INTOSC oscillator: CLKIN function disabled
_FOSC_EC EQU H'3FFF'; EC: CLKIN function enabled
_BOREN_OFF EQU H'3FF9'; Brown-out Reset disabled
_BOREN_SBODEN EQU H'3FFB'; Brown-out Reset controlled by the SBOREN bit in the BORCON register
_BOREN_NSLEEP EQU H'3FFD'; Brown-out Reset enabled while running and disabled in Sleep
_BOREN_ON EQU H'3FFF'; Brown-out Reset enabled
_WDTE_OFF EQU H'3FE7'; WDT disabled
_WDTE_SWDTEN EQU H'3FEF'; WDT controlled by the SWDTEN bit in the WDTCON register
_WDTE_NSLEEP EQU H'3FF7'; WDT enabled while running and disabled in Sleep
_WDTE_ON EQU H'3FFF'; WDT enabled
_PWRTE_ON EQU H'3FDF'; PWRT enabled
_PWRTE_OFF EQU H'3FFF'; PWRT disabled
_MCLRE_OFF EQU H'3FBF'; MCLR pin function is digital input, MCLR internally tied to VDD
_MCLRE_ON EQU H'3FFF'; MCLR pin function is MCLR
_CP_ON EQU H'3F7F'; Program memory code protection is enabled
_CP_OFF EQU H'3FFF'; Program memory code protection is disabled
_LVP_OFF EQU H'3EFF'; High-voltage on MCLR/VPP must be used for programming
_LVP_ON EQU H'3FFF'; Low-voltage programming enabled
_LPBOR_OFF EQU H'3DFF'; BOR disabled
_LPBOR_ON EQU H'3FFF'; BOR enabled
_BORV_HI EQU H'3BFF'; Brown-out Reset Voltage (Vbor), high trip point selected.
_BORV_27 EQU H'3BFF'; Brown-out Reset Voltage (Vbor), high trip point selected.
_BORV_LO EQU H'3FFF'; Brown-out Reset Voltage (Vbor), low trip point selected.
_BORV_19 EQU H'3FFF'; Brown-out Reset Voltage (Vbor), low trip point selected.
_WRT_ALL EQU H'27FF'; 000h to 1FFh write protected, no addresses may be modified by PMCON control
_WRT_HALF EQU H'2FFF'; 000h to 0FFh write protected, 100h to 1FFh may be modified by PMCON control
_WRT_BOOT EQU H'37FF'; 000h to 07Fh write protected, 080h to 1FFh may be modified by PMCON control
_WRT_OFF EQU H'3FFF'; Write protection off
; IMPORTANT: For the PIC18 devices, the __CONFIG directive has been
; superseded by the CONFIG directive. The following settings
; are available for this device.
; Oscillator Selection bits:
; FOSC = LP LP oscillator
; FOSC = XT XT oscillator
; FOSC = HSHP HS oscillator (high power > 16 MHz)
; FOSC = HSMP HS oscillator (medium power 4-16 MHz)
; FOSC = ECHP EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
; FOSC = ECHPIO6 EC oscillator (high power, >16 MHz)
;etc
; 4X PLL Enable:
; PLLCFG = OFF Oscillator used directly
; PLLCFG = ON Oscillator multiplied by 4
; Primary clock enable bit:
; PRICLKEN = OFF Primary clock can be disabled by software
; PRICLKEN = ON Primary clock enabled
; Fail-Safe Clock Monitor Enable bit:
; FCMEN = OFF Fail-Safe Clock Monitor disabled
; FCMEN = ON Fail-Safe Clock Monitor enabled
Yes.What does the previous table tell about the configuration word default reset value? That every bit is set as "1"?
Yes.Why the "1/1" and "R/P" statements in the top row? Because the bit is both Readable and Programmable?
"Writable" = can be written to under program control at execution time (none of the bits are identified with a "W", so none of them can be written to in your program)What's the difference between "Writing" a bit and "Programming" a bit?
Interesting ... does that mean that the chip can rewrite its own CONFIG register and then reset itself so as to work under different conditions?If you change/program the CONFIG register the PIC has to be reset
; 10 JUL 2018, 10:23:51 AM:
; Generator controller for the PIC10LF322
list p=10LF322 ; list directive to define processor
#include <P10LF322.INC> ; processor specific variable definitions
; - Flash memory self-write protection off (default state)
; - Brown-out reset low trip point is selected (default state)
; - Low-power Brown-out Reset is enabled (default state)
; - High Voltage on MCLR pin must be used for programming
; - Program memory code protection disabled (default state)
; - MCLR pin set as digital input
; - Power-up Timer disabled (default state)
; - Watchdog timer disabled
; - Brown-out reset is enabled (default state)
; - Internal oscillator is activated
__CONFIG _LVP_OFF & _MCLRE_OFF & _WDTE_OFF & _FOSC_INTOSC
; movlb 31
movlw low(_Config1)
movwf count
movf high(_Config1),w
movwf temp
nop
; The following program reads the state of the R1 pin and outputs it at the R0 pin
; Reset and Interrupt program memory locations
RESET_VECTOR CODE 0x000 ; processor reset vector
goto Init ; go to beginning of program
INT_VECTOR CODE 0x004 ; interrupt vector location
goto Init
; Main program start
Init
;the reference Clock output bit CLKROE is disabled by default, we'll leave it that way
;set the internal oscillator frequency to 31 KHz (the lowest possible), this is done
;by clearing the IRCF bits, which belong in bit locations 4, 5 and 6, respecively
movlw b'10001111' ;the W register has been loaded with the IRCF bits as zeroes
andwf OSCCON, f ;AND the W register with OSCCON, storing the result in OSCCON
;************************************* I/O definitions ***********************************
; - set RA1 as an input, active low ... this means that we also have to enable its
; internal weak pull-up
; - set RA0 as an output, active high ... leave RA2 as an input ... RA3 can ONLY be
; an input
;BANKSEL PORTA ;this instruction is not necessary with the 10LF322, since it only
;has one bank of SFRs
movlw b'00000011' ;set appropriate pin states BEFORE enabling their i/o functions
movwf PORTA ;R0, will be set as an output, with its startup state as one, R1
;will be set as an active-low input with an internal pull-up
;enabled, therefore it must be latched as one ... all other bits
;are inconsequential
bcf TRISA, TRISA0 ;clear bit TRISA0 located at the TRISA register, effectively setting
;R0 as an output, all other bits remain in their defualt (1) state
;the following instruction is unnecessary, since all internal weak pull ups are enabled
;by default when a pin is configured as an input
;bsf WPUA, WPUA1 ;activate the internal weak pull-up of the RA1 pin
ProgramLoop
;RA1 is an input, active low, which will go low when the button is pressed and connects
;it to ground ... therefore under the next logic, RA0 will remain high until the button
;is pressed
btfss PORTA, RA1 ;skip next instruction if the button is unpressed
goto Clr_Ra0
goto Set_Ra0
;yeah, I know that this logic structure can be imporved substantially, but hey, I'm
;learning here!
Set_Ra0
bsf PORTA, RA0
goto ProgramLoop ;loop endlessly through this logic
Clr_Ra0
bcf PORTA, RA0
END
[LIST=1]
[*]RESET_VECTOR CODE 0x000 ; processor reset vector
[*] goto Init ; go to beginning of program
[*]INT_VECTOR CODE 0x004 ; interrupt vector location
[*] goto Init
[/LIST]
Good call... I understand exactly what you're saying ... gonna correct the code right nowLooks worth a try!
I understand that you are not enabling interrupts, but this structure:
would lead to problems if they were enabled. An interrupt is like a "call" , if you don't return from it, you will get a stack overflow and reset. At Line 5, use "retfie". That instruction returns from interrupt, thereby clearing the address, and resets GIE.Code:[LIST=1] [*]RESET_VECTOR CODE 0x000 ; processor reset vector [*] goto Init ; go to beginning of program [*] [*]INT_VECTOR CODE 0x004 ; interrupt vector location [*] goto Init [/LIST]
John
It certainly is ... there's an inc file for it, plus it's listed in the Processor pull-down list in the main window.Never used MPASM v5.77, but is that device supported?
Max.
I was able to make it work as it is using MPLAB X IDE v4.20, which is the main program for the whole software ... of course, I don't like it one bit, but I still have to use it to load the program into the MCU using the PICkit3 device programmer. I'll let you know how it went.Try this, changes highlighted:
"Code" is a directive for relocatable code. You probably want "absolute."
Same goes for the vectors.
Helpful but not required to define radix as decimal. That's how my brain works. Default is hex, I think.
You may get an error at the config directive. Click on "configure" in the Assembler and be sure the correct device is selected. After those changes, it compiled fine for me.
Sorry my first review was so sloppy. Of course, getting something to compile is the lowest hurdle you will face.
Edit: My version of MPASM is 5.51. The device is covered in it, except there is no template for it.
