Ok thanks for reply, I am in the UK so I will try searching on ebay again using different search terms.
Ok thank you very much, this is far beyond my minimal knowledge but I will have a look and continue learning. Thanks again... JohnGoing back to your thread-starting post, the tank circuit along with the NPN transistor (likely with a small pico-farad capacitor across the emitter and collector) is called a Colpitts Oscillator.
http://www.electronics-tutorials.ws/oscillator/colpitts.html
You may also want to look at the other types of oscillators such as the Hartley
http://www.electronics-tutorials.ws/oscillator/hartley.html
http://electronics.howstuffworks.com/oscillator.htm
I don't want to kill you with links, but the colpitts is the most common among basic RF transmitters. The problem with most of these types of oscillators is frequency drift, either when touched or if your hand comes near the tank circuit. they are great for learning how they work...especially with harmonics (spurious frequencies). If your unfiltered oscillator center frequency is 120MHz, you will have harmonics at 240MHz, 360MHz, 480MHz and so on. Without a spectrum analyzer, it is difficult to determine the center frequency. If the signal goes away after you back away from the circuit a few feet, you have a harmonic. If you want a more stable oscillator without much harmonics, consider using a crystal controlled circuit. A bit more design is required, but the payoff is worth it.
Go to the link below and click on APP NOTES
http://www.crystek.com/home/crystek/appnotes.aspx
