LCD Display not working
Zekey
Joined Jun 9, 2023
Hello, this is my first post.
I have an Insignia LCD TV and I disconnected the LCD display from the main circuit board. The thin almost foil like housing on the outlet (that takes the bus strip plug that goes between the TV main circuit board and the secondary, LCD circuit board) of the secondary, LCD circuit board fell off. Whereas the plug still goes into and secures itself into the secondary, LCD circuit board the LCD no longer turns on even when the TV power indicator is on. Is this thin metal housing over the outlet necessary for transmitting the electrical current and data?
In two very small places the metal housing was soldered on each side to the circuit board.
Please see picture.
Thank you very much everyone.
Please see picture.
The thin metal housing over the outlet on the secondary LCD circuit board is likely important for proper electrical connection and data transmission. Its absence may be causing a malfunction in the LCD display, resulting in the TV not turning on. The soldered connections suggest its significance in the circuitry.
R!f@@
Joined Apr 2, 2009
10,014
Please see picture.
It does not fall off by itself.
The metal part is used to secure the cable into the connector for proper connection. You need to fix it or replace tht connector.
Did you pull the cable or what ?
What was the actual problem you had ?
