LC circuit needing help
bushrat
Joined Nov 29, 2014
209
Does the transformer (or inductor) has any inductance? If there is 0 inductance, then it will see it as a short to ground, hence 0 V.
bushrat
Joined Nov 29, 2014
209
whats wrong is you need a resistor on the left side
Not necessarily, capacitor has reactance (depending on the frequency of the source voltage) Inductor (or transformer in this case) would also have inductance..
Xc = 1/(2*pi*f*C)
Xl = 2*pi*f*L
Edit:
There are some basic tutorials on this website that will help you understand reactance and inductance
https://www.allaboutcircuits.com/te...rrent/chpt-4/ac-resistor-circuits-capacitive/
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-3/ac-resistor-circuits-inductive/
bushrat
Joined Nov 29, 2014
209
cap is 200 p (assuming 200 picofarads).
1/(2*pi*f*C)
60 Hz = 13.262 M ohms
100 Hz = 7.95 M ohms
400 Hz = 1.989 M Ohms
1 Khz = 795 k ohms
10 Khz = 75.5 K ohms
1/(2*pi*f*C)
1 Khz = 795 k ohms
But the cap charges instantaneously without a resistor, that is zero time, at least in simulation. isnt that a problem ? if I try adding a capacitor without a resistor to my simulator it fucks it up, and it breaks the simulator man
38,504
The resistance in the TS's circuit if provided by the transformer load R3, which is reflected through the transformer to the primary as determined by the square of the turns ratio.
bushrat
Joined Nov 29, 2014
209
why not..........are you playing tricks on me?
RC constant applies in DC source, not AC.
Capacitor blocks DC, but allows AC
Inductor allows DC, but blocks AC
the above statement about AC applies at certain frequencies, different frequencies will have different effect on caps and inductors.
