LaTex inline syntax doesn't render properly
jrap
Joined Jun 25, 2006
1,128
Hi @imre,
I've corrected the LaTex in your post. Each block needs to be wrapped in two $$'s.
A preview function is a great idea, I'll look into it!
Thanks,
Rob
imre
Joined Feb 15, 2016
Hi @imre,
Thanks,
Rob
Ok, thanks a lot for the help. It' not worth dealing with that comment any more it looks after your edit just fine, but what I meant is inline LaTex that is what would be rendered in the same line as some surrounding text. For example the "a+b" LaTex expression in the "The a+b sum" sentence, with the whole sentence rendered in one line. With other sites/engines supporting LaTex I wrapped in single $'s these kind of inline expressions. $$ is used for block expressions which render on their own separate line.
Thanks for looking into the preview function, please also consider an edit function.
