There is no indication on the case. Test it with a multimeter. Or an LED with a 1/2W 2k resistor...I've found an 18-20c AC/DC laptop adapter and have adapted and soldered. I have taken the inside wire of the cable to be positive, the outside wire core to be return.
Hi, thanks for responding.There is no indication on the case. Test it with a multimeter. Or an LED with a 1/2W 2k resistor...
That’s a pretty broad statement... The only answer is that “it depends”. If the case touches you, nothing is going to happen. If the power output isn’t connected to a complete circuit (e.g., one wire is disconnected. Nothing is going to happen. If it’s connected in a circuit, maybe something will happen.It's not going to destroy anything it touches?
No.I've got no LEDs or resistors, will a standard buzzer do?
View attachment 228282View attachment 228282
So it depends on what you mean by touch and what it is touching.
- If the circuit is only rated for a lower voltsge (e.g., 2 volts), the circuit will be destroyed
- If the output is shorted together, the power may stop. The device may have short-circuit protection and recover. Or it might not.
- If the output is connected in reverse polarity, the circuit may be damaged
It looks fine. It will probably work. It may or may not work. Depends now on correct polarity and the current required by the unit. If it needs more than 3.79A, you’ll likely have issues.Hey,
I more mean the concept of using that laptop charger to power DC. Since it provides 18-20v, and the unit I want it to power is 18-32v, the voltage should be fine. I've just never messed with AC converters before.
Cheers
Great. I'm off to immediately get a multimeter right away, which I will have absolutely no idea how to use haha.It looks fine. It will probably work. It may or may not work. Depends now on correct polarity and the current required by the unit. If it needs more than 3.79A, you’ll likely have issues.
