Kirchoff law problem
logearav
Joined Aug 19, 2011
243
Revered Members,
Please go through my attachment. I have been asked to find the magnitude and direction of current through the 10 ohm resistor. The answer that is given in the book is 1/23 Ampere from A to B.
But i solved as given in the attachment but i got the answer as 5/37 Ampere which is I3...the current which I assumed to pass through 10 ohm resistor. Since Please help me where i went wrong.
MKCheruvu
Joined Nov 20, 2012
30
Solving this problem by super position theorem :
Ir10 due to 8v source = 16/74 and
Ir10 due to -2Vsource = -6/74
Net Ir10 Current = 10/74 =5/37
The answer is same
33,188
Yet another approach:
Remove the 10Ω resistor and find the Thevenin equivalent between A and B for the rest of the circuit.
Rth = 12Ω||8Ω = 96Ω^2 / 20Ω = 4.8Ω
Vth = -2V + 10V(8Ω/20Ω) = +2V
Now put the 10Ω resistor back in and you have:
I = 2V/(10Ω + 4.8Ω) = (1/7.4)A = (5/37)A
The Point: If you can work the problem several different ways and all produce the same answer, then there is good reason to believe that your answer is correct and the book is wrong (unless every method you used had some flaw in common -- so be sure to be on the lookout for that).
You come up with an answer of (5/37)A. So check the validity of the answer starting from the answer itself:
V_B = 0V (I'm defining B to be ground). This means that
V_A = (50/37)V
This makes the current toward A from the left
I_12 = [8V - (50/37)V]/12Ω = [246/(37*12)]A =(41/74) A
Likewise, the current toward A from the right:
I_8 = [-2V - (50/37)V]/8Ω = [-124/(37*8)]A =(-31/74) A
Now we can see if KCL is truly satisfied at Node B:
I_12 + I_8 =? (5/37)A
(41/74)A - (31/74)A = (10/74)A = (5/37)A
The Point: In a surprisingly large number of problems, both in school and in the real world, it is possible to verify the correctness of your answer from the answer itself. Get in the habit of doing so. You grades will probably take a significant turn for the better and you will be less likely to kill someone down the road because of an undetected error.
