Kirchhoff law + Ohm Law = headache
Bigcountry
Joined Jul 4, 2008
76
I thought I would be original with a title and humorous also. which after trying to figure out all this problem has driven me crazy.
I tried the product over sum rule and it didn't seem to work and I got it all screwed up on superposition. so maybe someone can get me get the problem #3 started.
thank you for all your help or insight.
Couple ways you could do it.
You could reduce the circuit to one resistor quite easily and determine the total current. Then open the circuit back up and use ohm's law/KCL to determine the needed current's/voltages.
In general, i personally tend to use KCL pretty much all the time though cuz i'm most comfortable with it. So i see 2 unknown nodes. You could just write KCL equations at those nodes and solve those 2 equations by a simple substitution.
Hope that helps get you started!
Bigcountry
Joined Jul 4, 2008
76
I got .2 A for the total current by reducing the circuit to one resistor. ok now what do you mean by "opening the circuit back up"?
I just mean sorta work backwards. Reverse the resistor combinations (that is, turn those combined resistors back into series/parallel resistors) one by one while calculating currents and voltages.
Does that make sense?
If not, i can draw it out for you... sorta illustrate what i mean.
Bigcountry
Joined Jul 4, 2008
76
ok so that I found the total current is go back and work it and find the voltage at each series/parallel then in turn find the current at each one??? I am starting to get what you did but I am struggling here. thanks for your help thus far.. i have almost got it.
so I take the total at each parallel and then find the voltage then the current ?
MareBear
Joined Oct 29, 2008
22
you use current divider to find the current at each one and with that you can find the voltage
A Homework Help 17
