Keyless entry
Kman1792
Joined Jul 9, 2017
Hi I'm a new to the forum bit I need some help I'm trying to wire a keyless entry on my 1995 Isuzu trooper ls from what I read in the installation book I have every thing wired right bit when I use the key thob that is with the keyless entry it blows the fuse in the vehicle to the lock buttons in the doors do I need to reverse the polarity of the lock and unlock wires coming from the after market keyless entry brain and if so what do I need to buy to do so
IMP002017
Joined Jan 28, 2017
192
You should make sure that your system is wired as stated. Please note that the Door locks being Ground don't mean that you can use the Keyless without Relays. Unless it is a unit with Relays already built in. Most times the output for the doorlocks are only like 250mA and your locks need more constant ground. This can be T-Tapped into the lock system.
May want to make sure your system is using a ground to your locks. If it is tripping the fuse that sounds like your tapped into the wrong wire for the doorlocks.
Constant 12V+ (Color) White/Black IN Ignition Switch Harness
Starter (Color) Black/White IN Ignition Switch Harness
Ignition (Color) Black/Yellow IN Ignition Switch Harness
Ignition 2 (Color) Black/Red IN Ignition Switch Harness
Accessory (Color) Blue IN Ignition Switch Harness
Tach (Color) Black/Red AT Multi Coil Pack ((UNDERHOOD))
Brake Switch (Color) Green/Yellow AT Brake Switch
Trunk Pin (Color) Black/White (-) Rear Light or Loom from Fuse Panel
Parking Lights (Color) Green/Red Passenger's Kick Panel
Head Lamp (Color) Red/Black (-) Light Switch
Hood Pin (Color) Red/White (-) Hood Pin Switch or Brown/White (-) at Theft Module
Factory Disarm (Color) Orange/Red (-) Driver's Kick panel or Orange/Black (-) at OEM Alarm
Door Trigger (Color) Black/White (-) Passenger's A Pillar or Loom (-)Loom from Fuse Panel
Door Lock (Color) Green/Red (-) Driver's Kick panel
Door Unlock (Color) Green/Blue (-) Driver's Kick panel
Horn Wire (Color) Black/Orange (-) Steering Column
