KBPC-240D DC Motor Controller has no output
ScottMR
Joined Apr 4, 2024
19
I have used the S8015L, S8020L, S8020LTP SCR's in the past.
Hi Max,
I think that I have found bad SCR's. First, I tested the three diodes by pulling one lead from the circuit board. With the multimeter in diode test mode, all three read OL when measuring between cathode-anode. Measuring anode-cathode (red-black) gives 0.527V for D31, 0.530V for D32 and 0.542V for D33.
For the SCRs, I did a resistance test between anode-cathode first with gate disconnected and second with gate touching anode to trigger it. Without the gate triggered, I should essentially read open circuit. With the gate on, I should see a low resistance. What I found is that without the gate triggered, I still read a high resistance regardless of lead polarity.
SCR1
R a-k (no trigger) 17.1M
R a-k (triggered) 49.2 ohms
R k-a (no trigger) 18.7M
SCR2 readings were similar.
Looks to me like I need new SCRs. F7260-ND from Digikey ( SCR 800V 20A TO220AB-L ) should fit the bill.
Pyrex
Joined Feb 16, 2022
542
Voltage on the speed potentiometer goes from 0V to 11.6V (center to one side. It is probably part of the 12v control circuit. Both the 7812 and 7912 are outputting the correct voltage. Also, the output relay on the right seems to work. When I hit the Run switch, the relay pins close as they should.
are you sure? I see 7915' and 7815'
Pyrex
Joined Feb 16, 2022
542
There are three ICs with 14 pins on the PCB. I guess it's the opamps. Measure the voltages on their inputs and outputs and look for a faulty opamp. It's a pity that the manufacturer did not provided the circuit diagram
ScottMR
Joined Apr 4, 2024
19
Those three are L324 quad op amps. That means 12 different opamps to check when I don't even have a schematic to follow. It makes it near impossible to figure out what signal should appear where.
Pyrex
Joined Feb 16, 2022
542
It is not easy. But opamps are the most suspect components. You can look at their outputs and inputs with an oscilloscope.
If the voltage at the "+" input is higher than at the "-" input, the output must be close to +15V, and vice versa.
If it is worth repairing the controller, of course
ScottMR
Joined Apr 4, 2024
19
I was just thinking that the reason they are there is to provide a changing output signal dependent on what else is going on in the circuit. I'll scope them out and report back.
