I joined mainly so I could read the attachments but might post something latter. The email from jrap "jrap started a new personal conversation with you." But I don't know how to find it and reply. Sorry this is so ignorent. whitehaired novice
Thanks, I found it under my tag--though the line is orange on my monitor.On the page I see, the label is, "Inbox"
High on the right in a dark blue horizontal band about 0.35 inches thick.
That's where, "conversations" or Personal Messages show up.
Yes, you folks solved my problem. Should I--can I? close this thread?whitehaired novice......drop down menu from username at top. Select preferences. Select fluid view. See if that's any better.
No. Threads live on for eternity as long as humanity survives.Yes, you folks solved my problem. Should I--can I? close this thread?
Thanks. I'm learning the rules--slowly.No....you can't close a thread. Just let it go. When you got something else to say or ask....just start a new thread......just guess what sub forum to put it on....that will be fine.
This is the first site I joined. Lot's to learn. Don't worry. We have all made noobie mistakes.Thanks. I'm learning the rules--slowly.
ThanksThis is the first site I joined. Lot's to learn. Don't worry. We have all made noobie mistakes.
We recognize them. They get fixed. Very small problem.![]()
There are two color schemes, the pleasant blue (vB 3.x Fluid) and hideous orange (AAC Updated v3) -- guess which I preferThanks, I found it under my tag--though the line is orange on my monitor.
Anyway, I'm good now. Thanks.
Thanks. My problem is solved. Please, save bandwidth and don't reply to this thread.There are two color schemes, the pleasant blue (vB 3.x Fluid) and hideous orange (AAC Updated v3) -- guess which I prefer.
The new orange one is the default.
You can change them either by settings in your preferences, or by a quick link that is on every page. On the blue scheme it is in the lower left corner of the page. On the orange it is in the upper right corner. Try them both out and pick the one you like better.
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Change of email address | Feedback and Suggestions | 5 |
| Similar threads |
