Just a small rant... what is +/- 5% of 0 ?
narkeleptk
Joined Mar 11, 2019
599
I've always heard 0 resistors do not use tolerance ratings so maybe its just the way the manufacture labeled them because of their system.
35,268
I just got some 0 Ohm resistors with 5% tolerance. Seriously anyone know how to do this math?
Simple.
5% of 0 is zero,
100% of 0 is still zero.
Hence you cannot state any % tolerance on 0.
However, the manufacturer can state an absolute tolerance, for example, 0 + 10mΩ
Analog Ground
Joined Apr 24, 2019
460
I have used them in a circuit where I thought I might want to put a non-zero value someday. Such as in series with another resistor to tune something. Mostly in the old days when precision was more expensive than now.
35,268
Manufacturers don't make resistors, measure them, and then put a label on it.
The manufacturing process is very precise.
They make xxxΩ resistors to ±y% to very precise specifications.
Hence they make 0Ω ±5% 1/8W resistors using the same process that they make 1Ω ±5% 1/8W resistors.
So that is what you are getting.
35,268
When you have to stock, inventory, and catalog your components, where do you put the 0Ω resistors?
They go at the starting lineup of 0805 ±5% 1/8W series. Simple, duh!:rolleyes:
SLK001
Joined Nov 29, 2011
1,549
Well, since there really is no such thing as a zero ohm resistor, the tolerance spec needs to be a ± value, not percentage, like @MrChips states above.
I have used them as jumpers on a complex single sided board, when the backside had to be clear of traces.
