Hi Guys and Gals,
I haven't been messing with electronics for a while and now I have a small project I want to make. I need to light 3 IR Led's:
Forward Voltage 1.5
Forward Current 100mA
Battery 2-AA for 3V
I could do this easily a few different ways with just resistor or resistors depending if parallel or series circuit and battery type and voltage, but the efficiency would be lousy. Someone suggested a "joule thief". Another suggested a Q5252 IC and yet another a LM3410 IC circuit. I bought some LM3410's and man are they small. And SMT too. I wasn't prepared for that.
The Q5252's are still on the way so I figured the regular old joule thief would be the way to go. I never made one and the designs are all over the place but a lot of differences between them. So I have some axial inductors on order, some transistors(2N3904), some resistors, I have capacitors etc. I never wound or used an inductor in my life but read enough to use it but was going to use the axial ones as I have no toroids(yet) and I want the project to remain small. I also ordered some SOT23 adapter boards for the LM3410 for later. That said, am I on the right track to make a joule thief with one transistor, an inductor, a resistor, and the 3 Led's in a serial circuit and expect it to do what I want? Any advice or help get me started will be much appreciated. First the bread board, then the pcb.
Forward Voltage 1.5
Battery 2-AA for 3V
