Jammer circuit simulation
ericgibbs
Joined Jan 29, 2010
21,578
Hi Majid.
This is a clip from AAC's Rules.
Moderation.
  • Clip:
  • Restricted topics. The following topics are considered "out of bounds" and will result in your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • Jammers intended for actual use in other than legal academic contexts
    • Amateur/homemade rail guns and other high-energy projectile devices
  • If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
WBahn
Joined Mar 31, 2012
33,224
You indicate that you intend to build one. Before we can let the thread continue, you will need to provide a lot more information. Essentially, you need to satisfy us that this will only be used in an approved academic environment with adequate safeguards to prevent jamming of any signal other than test signals that were being transmitted specifically for that purpose.
The circuit you show, due to its simplicity, if nothing else, appears to be a brute force barrage jammer. Of what legitimate academic use is it? How is it going to be used in this project?
