OKYou can get GSM modules from about Rs. 900/- onwards. Try Amazon.
Actually the ratio is 33% make to 66% break.The normal dial pulses at 10 pulses/sec. The make : break ratio is 1 : 2.
OK probably not important to get the make break ratio just right, but I would guess any old rotary dial phone would be closer to 60/40 than 50/50. The ring voltage in the US for POTS is approx 100VRMS at 20 Hz. The line voltage is -48V and the ring voltage "rides" on it.20 hz 48vac for ringing.
i got the exact number from dialler and i also added speed dial facility which include my friends and family.Actually the ratio is 33% make to 66% break.
Sorry I got that backwards it it 60% make 40% break.
are they costlyProblem is after using hand-phones for so long, I can't even remember my friends' phone numbers now. If I go back to the rotary dial phone I'll need to get a small note book to write down their phone numbers before I can use it....
The smart phones are actually making us stupid and lazy...
Besides where can you get those rotary phones cheaply?
Allen
I was working in telephone Exchanges, from GEC Strowger [step by step] to ARF Cross-bar to AXE Electronic SPC. These phones were very common in the 70s and 80s. I could get them free of charge from our telephone workshop. When push button DTMF phones were introduced. The rotary type phones were slowly disappearing and by the 90s, they were almost becoming obsolete. The last version that we used were NEC models.are they costly
the format of reading sms/call will be provided in the data sheet,and are using AT-commands.Hello everyone can someone help me with a c code to read an sms from a GSM module with pic16f877 i am using ccs compiler.
thanks!
