issues with treadmill control board mc2100 els 18w-zy
fouedkd
Joined Feb 13, 2023
9
i replaced the original board on decathlon domyos T5 by this board reference mc2100 els 18w-zy
first use the treadmill went at full speed for 2 seconds then shutted down
i checked the board with multimeter, found short on IGBT
re test after changing IGBT, at this time drive motor won't run
incline motor works, time and speed counter are displaying but drive motor won't run
somebody had same problem?
fouedkd
Joined Feb 13, 2023
9
i fogot something
when i press start button or speed number, time and speed counters are displaying, LED is blinking rapidly
thank you in advance for reply
fouedkd
Joined Feb 13, 2023
9
ok i'll try to test
thank you man, i am always following you on this forum
u are the best
always kind and helpful
fouedkd
Joined Feb 13, 2023
9
Did you have the right signal into the HD2 connector?
Is the LED lit ?
yes the led lit;
when i press start button the led blinks rapidly
but no voltage in both big capacities just 11 volts
i tested the scr on circuit it seems ok
voltage coming to gate 11 volts i don't know if it is the right voltage
fouedkd
Joined Feb 13, 2023
9
Sounds like the SCR or related circuitry.
This ramps the DC up for the Mosfet supply.
that's what i suspected
i'll change it and test again
what about 11 volts in out of the pin n°04 of the optocoupler S8025L going to SCR gate is that normal?
thank you
MaxHeadRoom
Joined Jul 18, 2013
30,806
There is usually pulses at that point so it is hard to read what the signal should be, but it sounds like that would be normal.
But the SCR and Opto would be suspect.
