Good idea.Try a couple of small diodes (eg 1N4148) in series with the 2k2 resistor so the logic output needs to go below 2.1v before base current will flow.
That works too, though with <1mA flowing you might not get much light out. Also a red led might not drop enough and a green might be too much, they vary so much these days with no-name cheap ones.Good idea.
Or an LED if you want more flashing lights.
That's another option but arguably overkill for this specific problem which is a simple level shift.Have a look at the schematic of this breakout -
https://www.sparkfun.com/products/12009
2 resistors and a mosfet?That's another option but arguably overkill for this specific problem which is a simple level shift.
DSO138 LCD issue (2) | Technical Repair | 17 | ||
S | CD4017 reset issue | Digital Design | 20 | |
S | Negative voltage supply issue | Power Electronics | 13 | |
Recapping and FM tuner station issue on Technics SA-5360 Stereo FM/AM tuner amplifier | General Electronics Chat | 8 | ||
J | Issue with powering a MAX16054AZT+T | Power Electronics | 2 |
by Jeff Child
