I have two boards connected to one another: the main board, which is responsible for charging, discharge, and battery monitoring of a pack, and the MCU board, which is responsible for communication and signals enabling and disabling various operations such as high voltage enable, battery voltage monitor, and so on. when I only used it to measure the battery voltage it was fine, when enabled the rest of the signals the boards started to consume over 700mA and the MCU got burned in the main boards there are serval protections and dc-dc convertors on the way to MCU.
I tested for shorts, signal contradictions ( inputs and outputs correctly ), and a current spike on both boards independently and didn't find anything.
connected a net of 1k resistor between MCU and the main to check for spikes and contradiction could not find any and they worked fine ( with the resisors). what else could be the cause and what test can I do?
