ISR routine Parameters and Returns
King2
Joined Jul 17, 2022
163
I have never seen nor came across the situation where need to pass parameter in interrupt service route or ISR that return any type.
I'm wondering if it's possible to pass parameters in an Interrupt Service Routine (ISR) or if we can have an ISR that returns any type ?
Sensacell
Joined Jun 19, 2012
3,787
ISR's cannot "pass parameters" in the usual "C" programming kinda way, but they can (must) interact with memory locations and peripheral registers.
Declare a variable 'volatile' if its molested inside an ISR.
Don't let ISRs read multi-byte variables asynchronously, imagine the mainline code is in the middle of doing a multi-byte multiply and the ISR fires and tries to read the resulting number - garbage happens.
BobTPH
Joined Jun 5, 2013
11,647
Tell us how you think one could pass a parameter to an ISR or how its return value might be used?
Let’s restrict this to the case of an external hardware interrupt. What might it pass or what might a returned value mean?
King2
Joined Jul 17, 2022
163
I don't know if this is useful or not, but an ISR is like a function in C language, right? And in C, we pass arguments to functions or get values back. So, I was wondering if it's possible to do the same with ISRs. Can it be done, or is it just not that useful in embedded system?
Papabravo
Joined Feb 24, 2006
22,111
There is no available mechanism for doing that. The alternative is to have memory locations with some rules about who can do what to those locations and when.
35,178
An ISR is not like any function in C language.
A function can pass arguments in the argument list or as a returned value.
Who or what is going to fill the arguments in the input list?
Who or what is going to receive the arguments in the output list or the return value?
There is no viable mechanism for doing either or both of the above. An ISR is invoked asynchronously. It can be triggered at any time or place in the program process.
BobTPH
Joined Jun 5, 2013
11,647
I suppose hardware could be designed to pass a parameter indicating what caused the interrupt. This is usually done by reading known hardware registers and by the fact that the different interrupts are vectored to different handlers. I see no compelling reason to change that. Any additional work done by the processor would likely increase latency, which is a bad thing.
You can manipulate multi-byte variables asynchronously if the actions are atomic in the non-interrupt context. You cant do this with interrupt masking or using atomic multi-byte hardware registers like 16-bit timer value latches.
