I have a remote controlled AC switch, which plugs into mains power and allows an appliance load to be plugged into it. Its wireless remote then allows this switch to be turned on and off from a distance.
Most of these kinds of switches available today will, if the mains power is cut (as in a power outage) result in the attached appliance defaulting to be OFF once the power returns to the remote switch. I have managed to find one that will, for a short time, retain "knowing" that the remote switch had been in the ON position, and when mains power is re-applied it will default back to having the load outlet switched ON. This condition will last only for a minute or so of mains power loss. After that, the outlet reverts to defaulting as OFF when power returns. So if you pulled the switch's cord from the wall outlet and then plugged it back in, the powered appliance will resume being on. If you wait a few minutes and then plug it back in, the powered appliance will be off.
I would like to make this switch remember to return as ON after a power outage for a longer period of time. A LOT longer. 12 hours, to be precise. I want to power this remote switch with a typical programmable wall timer, set to run 12 hours, then be off 12 hours, then repeat.
Experimenting, I have found a small electrolytic capacitor in the circuit which, while I monitored its voltage, starts out at 5.5VDC when the mains power is applied, and eventually bleeds off when mains power is removed. The 'memory' to default back to ON when mains power is reapplied is tied directly to the level of charge in this capacitor. As long as it exceeds 0.5V, the switch will remember to turn its relay ON when mains power is reapplied. This reminds me of some battery powered devices that have little internal "backup batteries", which will retain information while changing their main battery due to the temporary power provided by the little backup battery.
As such, I would like to find a safe way to keep that electrolytic capacitor charged, when mains power is removed, somewhere above 0.5V, so the remote switch's "memory" to default back to ON is preserved. Perhaps through the use of an additional battery or regulated DC supply.
I have some hobby electronics experience, but am far from well-versed in any particular aspect of it. I know that I can't just add a battery or secondary power source in parallel to the capacitor, because when the mains power were restored there would likely be a current passage back into whatever I had used as the auxiliary supply, and cause problems. So I am looking for a way to supply a few volts DC to this application but ideally have it either cut off when the mains power energizes the circuit itself, or else implement some sort of current limiting or blocking to prevent current feeding backwards into my auxiliary source of power. I'd also like to keep whatever circuit I have to make as simple as possible in order to do this.
I appreciate any suggestions on how to accomplish my goal.
