ISO pcb
Biltwellironco
Joined Jan 23, 2024
7
Good morning all, I am no expert on electrical devices in any sense, however I am designing a laser line for a particular saw. I'm in search of a PCB that can transform 110vac to 5vdc that also has a battery on it. The idea is that the particular accessory outlet on the saw that I will be using to power the laser is only hot when the saw is running, obviously that's not good while trying to match up a scribed line with a laser line. My thought here was to have a battery that can power the laser while the saw is off and the 110vac can keep the battery charged while the saw is running. I'm looking for something off the shelf if possible. I'm still in prototype phase and after speaking with a few PCB manufacturers, it wouldn't be plausible to have something custom made at this point.
Any info would be greatly appreciated.
Thank you in advance!
Let me know if there's any more info I can provide.
27,547
If this is a table saw or some other sort of system , not a handsaw, then the solution would be to add an unswitched outlet to the power switch box. That will require a box, an outlet, and a bit of wire. Total cost less than $10 (USD). Then you will be able to use a 5 volt wall-wart and not be concerned with any battery or open circuit boards.
Jon Chandler
Joined Jun 12, 2008
1,597
Add a USB charger to what I described in post #4. This is precisely what you asked for, although you'll need to put it in a small box.
Biltwellironco
Joined Jan 23, 2024
7
Much appreciated. I am looking for something off the shelf. I understand if that's not possible. However this will be a product that I will resell and I do not have the experience or liability insurance to sell an untested non-UL listed electrical device that I've assembled myself. I'm not trying to burn down anyone's shop haha.
AnalogKid
Joined Aug 1, 2013
12,141
This is not a specific recommendation, but an example of the genre:
https://www.ebay.com/itm/204386706205?hash=item2f9665a31d:g:tGoAAOSwZBVkpGrv&amdata=enc:AQAIAAAAwKAC4Nf9RoO5oIOvaltkvBYQ4OVwZ0SfIUkJAArS/zrJl3540iNqpGnDcbZyT9B/bhfgM9CnamxkSbSYBSuRu9iD1Z6svwuA33VQcNm651ajFjlOc1OchU91eaPMiVJasMK7dg/XdWQzW2tKh3z0ccXvUkJTNcoBqdgfRFh68CMGkqml8H2vRUC3ruqFKQ5IUzcYHkBRC2WDCI3r6dp7zrBdZqtHXpTud7PazcdwmFBygmMuZUuf24/HnQdZWjvQkw==|tkp:BlBMUJSuhL2nYw
This is a USB power pack. It is a lithium battery with both a charging circuit (5 V input) and an output boost converter regulated to 5 V. Most come with a charging cable that might not be long enough for your situation, but cables are cheap. You also need a 5 V USB wall wart.
Search ebay and Amazon for USB battery pack, USB power pack, USB power bank, travel backup power, cell phone battery backup, etc.
Most of these kinds of devices have the old, large, standard USB-A output connector. However, there are 4 (!) possible USB connectors for the charging input. Make sure your cable, or your wall wart with an attached cable, has the correct USB connector to match the device's input.
Here is one that uses AA batteries - no charger:
https://www.ebay.com/itm/313624203334?hash=item4905759046:g:g4AAAOSwEQ1guZrl&amdata=enc:AQAIAAAAwBMWUSjVOVHAomH+YmE3vwaCEMg1YYhDyWAUKDet0564/fZSE+QLiP5YBH+dKuuvrkv5h/ZUAXyR0ulw5OBI1Qr70xu4d5LTh3NgV6x7jZpmnH00Gd2Z/vAjeALWJqXOZsBt1dODqqfvyzIXaV934bynK+g2hrEr8WTgjJk0G8Bvy3WWmiEk/gSPj2MR3/ZADOHmNQa1PEI3TKJpFYzk5XbwSnNQxss4/8x7zqyc034Ixw6X8Y1jp1+1/v8IcOxEyQ==|tkp:Bk9SR9iTt72nYw
Once you've got the battery device you want, You will need an output cable that plugs into the battery pack and goes to the laser. You don't say what the current requirement for the laser is, or anything about its power input connection, but you have to figure that out no matter what the power source is. If it is a barrel connector, there are "universal" power banks that come with an assortment of barrel connectors.
All off-the-shelf components. Buy the wall wart from a reliable company so you know the safety certifications are not faked.
ak
Ya’akov
Joined Jan 27, 2019
10,238
Welcome to AAC.
Here is an example of a candidate module. Search on AliExpress (or elsewhere) for “5V UPS module” for more options. To provide the 5V input, use a standard phone type charger. You can expose the Type-C jack on the module or put your own on the box wired to the pads on the module, and and either supply or require the user to supply (much better) a charger.
This one uses two 18650 cells which will provide a very long run time.
You can also get single cell modules, or versions for LiPo cells.
Biltwellironco
Joined Jan 23, 2024
7
Welcome to AAC.
Does the battery need to match the 5v input? My laser module is 5vdc but all the batteries I'm seeing are 3.7v
