Grab any number of battery charge control ICs for Lithium Ion chemistry and start with the Typical Application circuit. Digikey search of "Battery Management System" will work.ok so my questions should be, how do i design a battery charger for 2S 18650s.
Were the batteries welded to the wires, soldered, mechanically connected. Ripping might not have been a good way to do it.Im using the same batteries that came with the BMS board, I just ripped them out.
If you want V/A.... use a multimeter using the resistance setting. If you want open circuit voltage and short circuit current use the part number on the solar panel and look at the datasheet. Otherwise, you need a "perfectly" sunny day, at 25C temp and measure the voltage at the terminals for open circuit voltage. Then, short the terminals together and measure the current that is going through the wire for short circuit current. The real operation of the panel is somewhere between there.... and it's a non-linear curve for both voltage and current. Good luck.How do I calculate the V/A required for the solar panel?
Depends on how they implemented the BMS. If it were me and I saw that the 3rd battery was "open circuit" I'd shut down the system. That's me and I'm kind of a wimp like that.And since this is a 3S then I cant use it for 2 batteries.
| J | LiPO Power Charging and Power Supply | General Electronics Chat | 4 | |
| J | Hoverboard Battery pack charging | Power Electronics | 5 | |
| B | 18650 Battery Charging | Power Electronics | 16 | |
| J | Follow up to battery charging current ? | General Electronics Chat | 23 | |
| N | Charging a hover board battery pack externally | Power Electronics | 2 |
