is this 115 or 220?
cgeod
Joined Jun 1, 2016
3
Not sure if this is the correct forum - if not - I apologize. If so, is there anyway you can figure out if the voltage generated by the switch in the attachment is 115 or 220 volts? Many thanks - chris
18,117
That's a circuit breaker, actually two ganged together, and there's not enough shown to tell what the voltage is.
12,156
Two AC power phases, one per breaker, going to a load that requires both or none be present. 120 Vac RMS per line with respect to Neutral, 180 degrees apart in phase, appears as a single 240 Vac power source to the load.
30,686
US domestic supply is 240v SINGLE phase with 120v C.T.
The picture shows a single phase double breaker.
