Is there a multimeter that can test inductance as well as volts, amps, resistance, capacitance, etc.
uraniumhexoflorite
Joined Oct 23, 2016
216
I have been looking to get a proper multimeter because the one I currently use is from harbor freight and regularly requires percussive maintenance to get a reading that's even close to being accurate. I did some looking around and found many great multimeters online, but couldn't find any that were able to measure the usual multimeter stuff (volts, amps, resistance) as well as inductance.
I have seen LCR meters before, but I want just one multimeter. I've read that inductance testing requires additional circuitry and that adds to the cost, but I figured that some company would add it to one of their multimeters and just increase the price. I was wondering if anyone knows of a multimeter that can measure AC/DC volts, DC current, resistance, capacitance, diodes, and inductance.
BobaMosfet
Joined Jul 1, 2009
2,211
I never buy a meter that I cannot test against a circuit against a known good meter. Did that once. Would up with a bad meter. Took it back to the store, and showed them how it failed, then went and got another, it failed too. In the end, I decided no more runaround with garbage meters, and went to a source I could trust-- Fluke. I got a Fluke 289. Pricey-- absolutely. But I'll never ever have to buy another one, or wonder if the meter is correct.
be80be
Joined Jul 5, 2008
2,394
I've seen Fluke's off too way off
This from there page maybe a job there Fluke Calibration they pay good LOL
no wonder they cost so much. But where i worked they had the meters Calibration checked 2 times a year or if you dropped it.
that was about once a month for some people.
smooth_jamie
Joined Jan 4, 2017
107
Personally, I'll always have more than one multimeter. It's good to have two in order to measure voltage and current simultaneously. You'll always need something separate for measuring capacitance, inductance, and low resistance to some decent accuracy. The UNI-T UT611 is probably a good compromise IMO between cost and accuracy.
