Is a Zobel network needed here?
Yabba Rays
Joined Oct 5, 2016
37
I understand that a Zobel network is added at the o/p of an audio amp to retain stability into the inductive load of the loudspeaker.
A TDA2040 amp is used here to modulate a 5 watt AM transmitter. Is the load inductive enough to suggest that a Zobel network is required? I doubt it will do any harm if added, but just wondered if it *should* be added.
(L4 is about 1 mH.)
Thanks.
Janet
Yabba Rays
Joined Oct 5, 2016
37
Add the Zobel network so that the amplifier has a load at high frequencies. A speaker's inductance causes its impedance to be too high at high frequencies).
The opamp's negative feedback is wrong:
Thank you for the correction. That design always had a poor reputation. There was a circuit board sold, but I don't know if it had the same error.
There is no loudspeaker, the load is the RFC and FET, but you suggest a Zobel network is still required.
Thanks,
Janet
Audioguru again
Joined Oct 21, 2019
6,826
I mentioned the loudspeaker because the amplifier oscillates when it has a high load impedance. The loudspeaker 's inductance causes its impedance to be high at high frequencies, therefore the amplifier needs a Zobel network when its load impedance is high, like on your circuit..
