If there is current in one direction that means there is at least one MOSFET conducting on the side that doesn't work anymore. Which one is it?one side does not turn on so load is only onedirecton
Can you please clarify this? First you are saying you have PWM at the 2110 inputs now you say one input is LOW. So what is it?ok gp0 goes low but why since it is a TTL input there should not be too much load on the micro. should i put 680 ohm resistors inline with gpo and Hin
G | H bridge problems using IR2110 | Power Electronics | 5 | |
B | h-bridge inverter using ir2110 causing problems | Analog & Mixed-Signal Design | 1 | |
A | ir2110 low side problems? | General Electronics Chat | 4 | |
S | ir2110 problems | General Electronics Chat | 50 | |
M | IR2110 High Side Problems | General Electronics Chat | 8 |
by Jeff Child
