Ir2101 gate current
Swap_4342
Joined Jun 3, 2018
16
Hiii, i am building bldc motor controller, i am using ir2101 ics as high side and low low side mosfet. My question is can this ics run 3 irf3710 mostet in parallel. Ir2101 can supply up to 130ma/270ma of gate current. i am using 18 mostet to build 3phase h bridge in my circuit. So will these ic are capable of driving 3 mosfet in parallel
Alec_t
Joined Sep 17, 2013
15,117
I suspect you'll need a driver with a greater current rating, but it depends on the MOSFET switching frequency. The higher the frequency the more current is needed. What PWM frequency do you intend to use?
DickCappels
Joined Aug 21, 2008
10,661
Check the input capacitance of the MOSFETs you intend to use. That will either dictate how many drivers you need to cause you to look at other MOSFETs.
Edit: Minor typo corrected.
